Date:    8-22-2012
Number of Hours:    1.75
Brief Description:    wing mods
Finnished NR 2 bracing, drilled and cleco'ed. Was able to use my cheap transfer punches again... Bonus! Started removing the 2 lower solid rivets for rib braces on NR 3&4 will try to do this without removing the ribs. They have some solid flush rivets in skin that I would rather not remove if I dont have to. Picts provided. I am able to spread the braces enough to work between them so I think its going to work ok. Was getting to late to use the air hammer so will have to try to get those buggers out tomorrow.
