This is the first part of a auxillary fuel system.The kit suplied fuel valve has been removed and replaced with a 3 way Andair fuel valve.In doing this I am able to isolate the fwd tank feeds from the rear tank feeds,thereby feeding the engine from the front tank feeds only ( during transfer ) and at the same time pump aux fuel back up into the main tanks via the rear fuel feed lines.Once transfer is complete ( 40 lts ) the valve will be repositioned back to the "BOTH" position.This tank assembly comes with a inline fuel filter, 12 volt pump and switching.The idea is to plumb it into the fuel line some where below the back seat.
