Date:    3-2-2009
Number of Hours:    8.00
Brief Description:    Build up engine assy
Build up fwd and aft engine mounts,modify rear L/H cylinder cooling fins to allow insertion of engine mount bolt,swap both induction manifolds and carburettors,install new ballance tube,rotate starter motor attach clamp,installoil pressure s/w,drill 4 x engine mount to engine bolts and install engine mount assy to engine..torque all hardware and saftey wire
