Date:    1-8-2009
Number of Hours:    8.00
Brief Description:    Modified glaresheild and new dash panel
Previously fit this new glaresheild to the boot cowl,today went ahead and put in lateral support with anchor nuts for lower dash and then positioned newly designed .063" dash into glaresheildset,set up position and removed again to fabricate mounting flange with f/glass on internal side of glaresheild.additional strength also put into glare sheild with chopped strand mating.Glare sheild will be attached to boot cowl on fwd flange with screws and nuts and anchor nuts yet to be installed on rear glare sheild flange for dash attachment.
Very happy with this job all turned out well
