Cut all fuslage stringers ,pre drill all stringers,install onto fuselage with rivets,anti chaff tape and lock wire applicable points to structure.Assembly both seat assemblies trial fit drill deburr and reassemble and rivet together ,install both seat covers then rivet on the four mounting chanels.trial fit into A/C.Trial fit all aluminium strips into baggage compartment,burn all rivet holes thru fabric with soldering iron,cleco assembly into fuselage and install rivets and washers,manufacture four lower mounting straps and instal with appropriate hardware.
