Date:    12-20-2008
Number of Hours:    16.00
Brief Description:    Battery box,access panel,controls,
Fit up all components of battery box and access panel,trial fit and trim,drill off all components.remove all parts and debur ,prime with 30-Y-94 primer and install anchor nuts and rivet all assemblies together.Install on A/C.Build up control jackshaft,get assembly running true,minimum friction,install all bushing and assemble into A/C,assembly universal joint and fit 2nd aft control rod,install all control bolts and saftey.Install rudder cable, pulleys and drill and fit fair leads
