3-31-2010 |
4.40 |
Skirts |
Sanded and cleaned rolbar and canopy bow of all excess SIKAFLEX. Installed canopy onto fuselage and checked alignment. Began trimming and fitting the left canopy skirt. Used a drill with cutoff wheel to trim the skirt to about 1/4" of the scribe line as per instructions. Because the canopy is from Todd's and not a stock Van's canopy the rear of the skirt may need to be modified slightly for a perfect fit. Drilled #40 holes in lower canopy rail for clecos and eventually to #30 for riveting the skirts in place. The top of the skirt will be SIKA'd to the canopy. |
