Date:    3-27-2010
Number of Hours:    6.00
Brief Description:    trimming
Completed triming of canopy to match the canopy bow and rollbar. Used a dremel with a 1" cutoff wheel. Drilled seven 3/32" holes through the canopy and frame for clecos used to hold the canopy and windscreen in position while applying the Sika 295UV. Separated the canopy from the windscreen using the dremel tool. Began preparing all surfaces for bonding with sika. Used 80 gril sand paper and alcohol to clean all surfaces. Applied masking tape and painters paper to all surfaces not to be glued.
