Date:    6-25-2010
Number of Hours:    4.00
Brief Description:    data plate and labels
installed the airplane data plate under the left HS using 1/8 pop rivets. Also installed all required markings and labels inside the cockpit. Noticed a slow leak in the left brake cyl. Removed the halon bottle, baggage floor and tightened the fittings. Added a jack for battery charging with the Battery Minder
