trim and fit all intersection fairings. Also, removed the magnflight starter and replaced with a B&C starter (new). Used adel clamps to secure oil cooler supply hose to the engine mount. Added firesleeving to the throttle cable as it was too close to the exhaust. Trimmed and fitted the landing gear access covers. Had to modify the upper intersection fairings substantially to fit correctly. used ester resin and 9 oz glass to fill the trailing edge so I could reshape to conform better with the landing gear leg. The fit is nearly perfect now.
