3-2-2014 |
2.50 |
Rear VS Spar |
It's too cold in the shop to work for extended periods, but completed final drilling with #30 drill, and drilled out the upper attach bolt holes. I also bought a bench-top sander today. Tried it with 80-grit - removes aluminum rapidly, but the finish is too rough. next time I'll switch to 120 grit, and see if that's better. |
