1-16-2012 |
2.00 |
Made HS rear spar jig mounts |
My first job today was to make and install brackets onto the jig for mounting the HS rear spar along the hinge line. Using my new cross-slide vice made it relatively easy to achieve a constant height above the mounting surface (and therefore a straight hinge-line). |
