Date:    3-1-2006
Number of Hours:    3.00
Brief Description:    Drilled the fuel tank attach brackets.
Made a bracket that will attach to the fuselage and then bolt to the fuel tank bracket to tie the two together, the fuselage bracket is notched so in case of an accident the wings will pull away through the notch.
