Date:    2-25-2006
Number of Hours:    1.50
Brief Description:    Setting the sweep on the wings.
After mounting the wings and leveling the fuselage side to side I put a plumbob on the outer edge of both wings and one on the inboard edge of both wings and then put a string on the floor lining it up with the two outer plumbobs to see if the wings wwere straight and they were. We then measured from the tip of each wing to a central point on the rear fuselage and both measurements came out the same.
