Date:    1-27-2008
Number of Hours:    3.50
Brief Description:    Shop prep and aft fuselage assembly
Today I rearranged the workshop to make room for the fuselage. I first took part of the wing stand down since I needed the space and the wood to make sawhorses, and then I moved everything to its new location. Turns out I misjudged how large the fuselage is (go figure) and will need to move everything at least one more time...I need a bigger garage! After I finished the workshop prep, I made some sawhorses and began fuselage construction.
While the photos make it look like I accomplished a lot today, the results are actually due to all of the work from previous sessions finally coming together...very gratifying. And it makes me realize the enormity of the task still ahead!
