Date:    12-3-2006
Number of Hours:    2.00
Brief Description:    Fuel tank construction
Attached and sealed a small cover plate over the tooling hole on the outboard rib, then attached the reinforcing plate on the forward portion of the rib. Then I attached the anti-rotation bracket and the fuel pickup fitting onto the cover plate. To finish the session, I sealed and attached the fuel drain and the fuel cap flange. The next session will be sealing and riveting the interior ribs.
