Began the session by final drilling the leading edge, then started on fuel tank construction. The first step in this process is to construct the Z-brackets that serve as the attach points for the tank on the spar web. The tank skin attaches by a number of bolts to the spar flange, and the platenuts for those attach points were completed early in the wing process. Today I finished six of the seven brackets for the left wing. The next step will be to assemble the tank for fitting and drilling the five holes on the opposite flange.
