Date:    4-17-2016
Number of Hours:    4.50
Brief Description:    Servo wiring and bundle organization
Today was mostly devoted to further planning and organizing to make the final push for wiring behind the panel. It seems that everytime I think I've accounted for all of the necessary wires, it turns out there is at least one more I didn't think about. Since the bundles behind the panel will be challenging to modify once the skin goes on, it seems worthwhile to spend as much time as needed to make sure I've accounted for everything.
One of the items on the list for this session was the autopilot wiring. TruTrak shipped a 25-pin connector with the autopilot box, so I spent quite a bit of time with the wiring diagram to make sure I knew what went where. I had previously ordered pre-twisted wire from Steinair to facilitate the servo wiring, so that will be put to use when I start fabricating the bundles to the center fuselage and wing.
