Date:    3-6-2011
Number of Hours:    1.00
Brief Description:    Helmet Box Door
I cut the 1" hole necessary to accept my 1.25" brass pull, which should arrive tomorrow. I also shaved the corners off the rectangular brass hinges... no real reason other than I just wanted to. This assembly is pretty much done except for the pull and varnish. I'm happy with the way it turned out.
