2-17-2010 |
2.50 |
Diagonal Braces and Aileron Webbing |
Finally!! A short break in the weather!! The temp got up into the 50s today... with a little help from the kerosene heater I was able to get the hangar warm enough to mix a little T-88. First things first... to clean the shop up after the messy prop blast I got last Saturday. Since all of the diagonal braces were already cut, all I needed to do was double check my alignment and mix a batch of glue. With the 1/16" ply web in place on the aileron, I was also able to cut the aileron brace to the proper length. I'll glue it tomorrow. |
