9-30-2009 |
2.50 |
Nailed Ribs to Spars and Drilled Rib LEs |
Got the wing ribs nailed to the spars using 3/4" AC nails. I also drilled the rib leading edges in order to bolt the leading edge to the ribs. I am using stainless 8-32 x 1 5/8" fillister head bolts and stainless washers and nuts. The bolt heads are recessed ~1/4" in order to allow 3/8" dowel to plug the holes. |
