Date:    8-12-2009
Number of Hours:    2.00
Brief Description:    Wing Ribs
When I attempted to trial fit the ribs onto the spars I found that the front spar fit snugly, but still allowed me to slide them laterally. The rear spar was a different story. The uprights were too tight by 3/64" or so. To fix this problem I used the Dremel and a sanding drum to remove material from the rear upright and then filed to smooth and square the corners.
