I trial fitted the top and bottom capstrips on the wing rib jig... both fit fine. I also fabricated a front block for the leading edge of the wing ribs (1/2" x 1/2" tapered block). Once I had one that fit snugly, I marked a 1/2" x 1/2" strip for 30 pieces or so. Once the outlines were drawn, cutting on the band saw and shaping one the disk/belt sander went quickly. I checked most against the original part and they were coming out very consistent. I plan to do the remaining wing rib parts using the same technique.
