Now that the fuselage has been framed up, that concludes the last of the large assemblies, therefore it was inefficient for the work benches to be positioned end to end (16' in length) any longer. Theresa and I seperated the two work benches and positioned one out of the way in an area where parts can be pre-positioned and drawings can be studied. The other bench will stay in the center for now, making it available for construction. We hung a much needed light over the welding table and another over the drawing table. The fuselage is now on an old steel cart, so it is mobile and can be moved out of the way when not being worked on. A day of reorganization will help improve efficiency in the months ahead.
