Date:    1-19-2007
Number of Hours:    1.00
Brief Description:    installed trim tab & cleanup shop
installed trim tab with temporary hinge pin. permanent hinge pin of correct length is supplied with fuselage kit. moved trim tab through full range to check for binds. no problems evident.
