1-1-2007 |
3.00 |
primed rudder & elevator |
Started the new year off right by getting some work done. Cleaned rudder and both elevator parts w/ acetone to remove oils, geases, fingerprints, etc and sprayed Vari-prime 615 self-etching primer. The darker colored areas visible on the skins are areas touched up w/ self etching spray can primer (SEM brand from Auto Color) when I have small localized spots, pre-riveted lines, etc and don't want to mix a whole batch of the two part stuff. |
