9-26-2006 |
1.50 |
Elevator stiffeners |
Worked on the elevator skin stiffeners. These are done exactly like the rudder stiffeners (ref 9/17/06). They're cut from aluminum angle and then tapered to fit inside the folded trailing edge skins. I cut the rudder stiffeners in the band saw, but did these with snips. I actually liked the results with the snips. Also match drilled the right elevator top stiffeners. Deburred everything. |
