Worked on the F-873 support brace that goes from the firewall to the next bulkhead in the forward baggage compartment. This brace will support the baggage door hinge. Had to trim the F-821B support flange strip for the brace flanges and hinge. Using the F-821 as a drill guide, I drilled the brace, the hinge, and the spacer. I had to make a .125" spacer plate to fit between the brace flange and the F866 bulkhead. I don't this is of concern, and I think it is due to the firewall upper portion being bent too far forward.
