Date:    1-28-2009
Number of Hours:    4.00
Brief Description:    aileron trim system, part 2
continued on with the electric aileron trim system. this is a simple system that really only requires mounting two brackets and installing the servo and push tube. an issue i had here was that the cut out (done at the factory in the quickbuild kit) is not located per the drawing. this caused the aft end of the starboard bracket's lower two rivets to line up in the previously cut hole vice the rib. since the upper rivets had mounting rib material, i just made a backing plate for the full row of 4 rivets. should work fine. did not power the system up, but it appears to be lined up ok and the push tube moved without excess force.
