Date:    12-26-2007
Number of Hours:    2.00
Brief Description:    more floorboard work
drilled yet a few more platenut holes. did some more deburring on the floorboards. also, trimmed the floorboards around the flap actuator blocks to make the floorboards removable without affecting the flap system.
did some planning on cabin side panels as well. i'm considering mounting the ELT in the space between the front and rear seats on the port side. it would be covered by a panel attached with screws via platenuts similar to the aft side panels.
also considering some thin plates screwed to bulkheads on the cabin sides for map pockets.
