12-24-2007 |
1.00 |
rear seat attach hinge |
i fit and drilled the rear seat hinges. i had previously made these hinges but felt that they did not sit on a true and square line and that that would cause the rear seat to sit at an angle. i made new hinges and located them using the 4-7/8" ref dimension from the floor/bulkhead interface as shown in the drawings. the result is a much straighter pin (hinge) line. see other post this date for flooring misalignment discussion. |
