Date:    7-11-2013
Number of Hours:    6.00
Brief Description:    Brake lines - fuselage - part 2
Continued on with the fuselage brake line segments. Finished up a little work on the portion in the gear towers and then fabricated some short U lengths to accomodate the Grove gear. These are not required with the stock gear, but installation (and follow on maintenance) is much easier if you swap the fuel vent and the brake line pass-throughs (essentially moves the brake line forward and outboard). I'm finding the tubing work difficult to make with only the bender - in other words, I need to supplement with hand bends. While structurally this is ok, it does take away from the professional look.
