8-4-2009 |
5.00 |
canopy frame |
worked for 5 hours and got very little completed. the side rails are clecoed to the canopy rails, the front rollover bar is clecoed to the canopy rails, the frame has been width adjusted at the forward bow and height adjusted at the aft bow. i drilled and mounted the c-806 slider block to the rear seat stop bulkhead. the 5/16 drill cut deeply into the slider block when making the holes for the nuts, but i'm going to use it anyway. the nuts were press fit into the holes and the bulkhead dimpled. next step is fit the plexiglass canopy. |
