1-19-2007 |
3.50 |
Battery Mount 4 |
I cut out, bent, lightened and TIG welded another battery box for the left side, including nut plates. I mounted the right side, but ran out of -4 nutplates, so it's provisionally mounted with nuts and bolts. A larger side bracket was made for the right side, as the majority of the wiring will be on this side and I will mount the starter and master contactor and current limiter on this side. Of course, it will have to be alodined, primed and coated, as well. |
