Date:    5-30-2010
Number of Hours:    2.50
Brief Description:    Nav/Strobe Light Wiring
I installed the strobe power supplies inside the outer ribs, forward of the front spar, using 3 each 10-32 self-retaining Monadnock fasteners. I made an extension cable for the high voltage wires from the supply to the strobe, so that I can disconnect the Nav/Strobe wires using Molex connectors while they are in plain sight when it comes time to remove the wingtips.
