3-27-2010 |
2.25 |
Wing Wiring 7 |
At the root, I labeled the wires and installed the Molex connectors, leaving enough length for a service loop and staggering their position. For the main fuel tank sender wire, a penetration to the inboard tank was needed. Fortunately, there is a jig-keying hole in the spar which allows the wire to pass with nylon tubing around it for strain relief. |
