5-16-2008 |
2.00 |
Fuel Lines 4 |
I fabricated the-6 fuel line which runs under the pilot's feet and runs up to a steel bulkhead at the firewall. Fiberglass insulating sleeve was placed around the tubing to avoid picking up heat from the exhaust tunnel. A -4 fuel line is tee'd up to a manifold where the fuel pressure sensor is mounted and a 90 deg fitting which will supply fuel to the primer. |
