1-28-2007 |
2.50 |
Installed landing gear, struts and brake calipers |
I raised the fuselage off the rotisserie using 5/16 nylon cord and a pair of two pulleys set into the overhead framing. I set it provisionally on a sawhorse with a couple 4 x 4's stacked on it, and had to deflate the tires to get the 8.5 x 6 tires mounted. There appears to be plenty of clearance between the landing gear and the calipers using the stock spacers. I wanted to install the tailwheel, but I need to purchase a 7/16 inch reamer first. |
