Date:    10-10-2010
Number of Hours:    0.80
Brief Description:    Trim Tab Fix
The left trim tab was noted to be rubbing against the elevator, presumably as the result of elevator or trim tab warping owing to the fabric shrinking process. I tried "adjusting" the fit with prying and application of an iron to the fibric in order to make it fit better, but no luck. I finally ended up making a pair of .050 inch spacers to shift the trim over. It was necessary to grind off a similar amount of material off the trim tab in order to accomplish the translation.
