Date:    1-23-2011
Number of Hours:    1.00
Brief Description:    Door Seal
The door skins have gaps to fit over the hinges which likely will result in a lot of noisy air leaks. I cut some small one inch strips of aluminum, alodined them and painted the inside portion and used two-part 3M urethane adhesive to attach them to the inside of the doors. After the adhesive cured, I sealed the outside with paintable 3M automotive seam sealer.
