Date:    5-7-2010
Number of Hours:    4.00
Brief Description:    Build Up of AeroInjector
Put the AeroInjector together. Drilled and tapped the mounting to accept the filter assembly. Then mounted the intake pipe, drilled the mounting tab to match the engine block and installed the AeroInjector.
