Date:    12-21-2009
Number of Hours:    9.00
Brief Description:    Spar Tunnel parts
Started working on the parts for the spar tunnell. The front sheet metal Z is very simple but the aft Z has several parts attached to it. I carefully aligned everything and pilot drilled. These parts will also require dimpling and countersinking so that there are no rivet heads protruding into the tunnel. That's a hint as to how tight a fit this will be for the overlapping wing spars later on.
