Date:    10-31-2009
Number of Hours:    8.00
Brief Description:    Aft Fuselage Assembly
After careful study of the plans and lots of research on the web looking at other builder's websites, I started working the tail wheel mount and all of the fittings.
Also fitted the bottom skin. This told me that I must have measured everything correctly because it fit like a glove. No adjustments necessary. I went ahead and drilled it into place to help keep the whole assembly in alignment. I can't say enough about the quality of the pre-cut and pilot drilled skins from Sonex. The time and effort saved is phenoenal.
At this point all of the crossties are fitted and pilot drilled.
