Date:    5-3-2013
Number of Hours:    3.00
Brief Description:    Match Drill & Dimple
Tonight Zeke and Zeb Westfall came over. Prior to them ariving I had put the entire rudder together and started to mach drill everything.
I realized I need to orderproseal for the leading edge which I did. It should arrive Monday or Tuesday. I also broke the tip on the machine countersink 1/8 carbide tip. Frustrating so now I had to order that also.
Zeke and Zeb dimpled and match drilled all the parts while I started prining the skins and frame. Productive night tonight!
