Date:    2-18-2007
Number of Hours:    7.00
Brief Description:    Finished fabricating the aft bulkheads
Had a productine day today. I completed the fabrication of all the parts necessary to build the tailcone. began the process of easing the edges. In particular I drilled the two spacers required for the elevator bellcrank. I made the tail tiedown bracket and used a tap to cut threads for the tiedown hook. The top 707 gusset required the aft edge to be eased so there would not be any sharp edge perssing into the skin as it is placer on top.Everything is ready for cleaning and priming. I will finally begin work on building the canoe.
