Date:    10-22-2006
Number of Hours:    6.00
Brief Description:    Elect. Wiring and safety wiring of Rt wing servo
This is actually two days of work into one. The first thing I did was to make up the twisted wiring bundle for the wing servo. That entailed soldering the appropriately sized wire to the female portion of the connector. Afterward I worked on safety wiring the servo to the support brackets and spar. I ran a wiring conduit from the servo to the inboard rib. I ran the wires seperately to insure no interference from the strobe wires to be ran in the large conduit. I used RTV to seal the end of the female plug. I opted to not use the plug cover since with it there was minimal room between the plug and top of the spar. I did not want to have the wire chafing on the top skin rivet shop heads. I needed to cut the plug screws to have then fit into the servo. I only need to get a couple star washers to install screws. I will also use locktight on the threads to insure they will not back out.
