Date:    4-23-2006
Number of Hours:    2.00
Brief Description:    Riveted and sealed parts on the ribs
Made enough proseal to not only reinstall the left tenk coverplate but also install parts to the ribs. Since the outboard rib needs a stiffener on the inside of the rib, I went ahead and riveted the stiffener with proseal. Next I installed the flop tube antirotation bracket and finished up by installing a -6 rivet in the outboard rib a tooling hole. That was followed by prosealing the #2 rib flapper door hinge pin in place...to keep it from binding or falling out during installation of the rib. Very messy but Accomplished without too much difficulty.
