Date:    12-14-2006
Number of Hours:    0.80
Brief Description:    Vertical stab
No pictures. Messed with the VS 705 nose rib to try to close the gaps between the rib flanges and the skin, particularly at the nose. After much fiddling I have come to the conclusion that the time spent making sure the rib flange was at a right angle to the rib web was wasted effort. The vertical stabilizer tapers from root to tip, so the rib flanges will not be normal to the web.
