Date:    4-29-2006
Number of Hours:    1.40
Brief Description:    HS cradle
Setup and cut out the airfoil waste in the HS cradle. Cut some aluminum angle to bolt the cradle pieces to. Drilled the angle and screwed them to the bench. I need to get some 1/8 X 3/4 bolts and nuts to fasten the cradle pieces to the aluminum angle.
