Date:    3-3-2004
Number of Hours:    6.00
Brief Description:    Throttle controls
Elected to replace the thermostat return cooling line with a bent tube to clean up installation. Took Autocad Dwg to Steffis to have dash Laser cut. Worked on the choke unit installing longer cables and detailed the throttle reverse bell crank. Detailed the fuel shut off bracket and drilled the throttle quad for the throttle control. Installed the throttle reverse bell crank
